The Rtech/Konrad Conversion
Hi Jack:
Lake Travis this weekend, you can talk to Paul there. He hasn't changed the pulleys yet, he's been too busy helping to get a customer's boat sorted out. That's another story...ask him about the Conquest project.
What is prop shaft ht in this installation? My TRS propsafts are 9" below bottom of boat and that seems like they drives are longer than typical. ould that be cause of not reaching full WOT RPM? I'm only turning 4000RPM with same props (21P Mirage) as I had on old drives.
tomcat, it's good to see people breathing new life into old gals. Nice work.
My '86 10-Meter Fountain with the Konrad conversion, Huber 950's, and a freshen-up of the motors performs and is as reliable as a new boat. All this at a fraction of the cost of a new one.
I'm interested in what you find with the P5's. I've got a set of P5X's that feel sluggish (with their larger blade surface area) when compared to my Quad IV's. By sluggish, I mean they seem to take longer to get up to rpm, and the seat-of-the-pants accelleration feel isn't there. It certainly is with the Quad IV's. I realize this isn't an apples/apples comparison (cat/v-bottom), but I'm interested in hearing about the P5's.
Nice work on your project, and welcome to the Konrad Family.
Brian
Brian
Hi Fred: The latest products and projects are not on the website yet. My bad; too busy building stuff. Feel free to give me a call at (416) 709-8714.
www.rtechperformance.com
Poorsche: Propshafts were about 5" below the hull with the TRS drives, which is pretty high. Mirage props could not get on plane but Bravo props never blew out. The Konrads raise the propshaft height by 1.65" from that point. The Bravo props still planed fine, but now we are running the P5s. More testing is required, but it's poker run season so it's going to spend the summer as is. I have never seen propshafts 9" below the hull on a performance boat. Is there a spacer installed in your drives that you can remove?
Hi Brian: I hear what you're saying about extra blade area; the Mercury Maximus is even worse. Since these props were designed for stepped hulls and the aeration/slip that apparently occurs on those hulls, they may have too much blade area for other hulls. The P5 was better than the Maximus on the 32 Skater project. I suspect a four blade and a bit of spacer might have been even better, but the owner was happy with the cruising speed and he's the boss.
[QUOTE=tomcat]Poorsche: Propshafts were about 5" below the hull with the TRS drives, which is pretty high. Mirage props could not get on plane but Bravo props never blew out. The Konrads raise the propshaft height by 1.65" from that point. The Bravo props still planed fine, but now we are running the P5s. More testing is required, but it's poker run season so it's going to spend the summer as is. I have never seen propshafts 9" below the hull on a performance boat. Is there a spacer installed in your drives that you can remove?
QUOTE]
Ther isn't a spacer--it looks like the bottom end was replaced. I thought it was a pretty extreme distance below the hull. Did notice the TRS manual suggest a 19P propeller instead of 21P so I'm gonna try that and going to try an old TRS Cleavery that I have to see what happens.
Thanks for reply.
QUOTE]
Thanks for reply.
Is it possible to put a TR lower on a TRS outdrive? The TR is longer and is designed to turn a larger dia. prop in cruiser applications.
Does a TR lower bolt up to a TRS upper? Good question. Anyone?
FYI, the Konrad 520 and 540 lowers share the same upper.
Cheers,
Brian
