Leaky Port Drive Fluid Inside Bilge Area?
Rough Seas Lie Ahead
It's not the trim pump reservoir since there's no signs of oil in or around the pump on the portside of the engine compartment. It's got to be coming from either the rear of the engine, or underneath? somewhere because I can see it slowly build up in the bilge.It was suggested maybe it's coming from a void area in the square box looking thing under the rear drive where the trim lines connect into. Apparently if something is not set right, the void will pool up and leak back into the bilge. Either that or a line somewhere is leaking...? Amny clues? It's of a course a 32 Sunsation with twin 496HO's: K-planes: and IMCO hydraulic steering.
