1988 Formula 242LS - mystery wire - HELP
I recently rebuilt my motor and connot find where a certain wire goes. It comes out as a single wire splitting out from the main engine wiring harness. It splits out on the boat side of the wiring harness. It is tan with a blue stripe. It is only long enough to make it to the following places. The Mercathode or the temp sensors on the thermostat housing. I am leaning toward the mercathode because the wire plastic wire loom that goes around the wire is slightly melted like it got up against the exhaust manifole. All guages work fine. Can anyone help a poor idiot that didn't write down where it goes.
Thanks,
Jimmy
Thanks,
Jimmy
SORE MEMBER
1 Post
Re: 1988 Formula 242LS - mystery wire - HELP
Tan with blue stripe is the buzzer circuit. Normally open, so if you touch it to ground with ign on your buzzer should sound.
It goes to the high water temp switch which is the larger of the two senders in the t-stat housing I believe
This wire can also be seen at the low oil pressure switch and the drive fluid bottle.
Toxic FORMULA
Probably the temp warning like wobble said.
Drive bottle warning wires are tan/blue also but has push on connector not a loop like oil and temp
It appears that the wire that is not connected is the tan wire with a blue stripe that goes up to the helm. I assume that it connects to the buzzer. If I take it to ground I get no buzz. Does anyone know where the tan/bl wire connects the other tan/bl wires on the engine sensors. Thanks, Jimmy
