Melted a piston?
Re: Melted a piston?
Sorry to hear that Gary. I always try to be optimistic. In this case, at least the thing didn't come apart. I'd concentrate on making sure that I found out exactly what caused the problem. Good luck! Lou
SORE MEMBER
1 Post
Gary,
this is one thread from my Good Friday holed piston. http://www.offshoreonly.com/forums/s...gine+tech+guys
Near the end you will see the cause of just one lean cylinder.
Dont think this would apply in a blower setup, but vacuum leak seems like a possibility.
Fortunately it's not my boat or money paying for it. Belongs to a friend, but he's not too mechanically inclined so I do most of his wrenching.
BTW, the problem was due to lack of fuel pressure. He ran it out of gas at WOT! Leaned out on the 1,2,&7 pistons, melting them. Inaccurate fuel guage, he said. Very expensive lesson for a boat he only ran 2 hrs.
SORE MEMBER
1 Post
I have an adjustable low fuel pressure switch that u can get from a speed shop that deals in NOS. Normally open switch that I have set for 4.5lbs add into the Mercruiser alarm system. I also added an auto style backup beeper to the mercruiser buzzer so that I can hear it at speed. Cheap insurance.
Good idea. I can get 5psi marine hobbs switches for about $10 and wire to the alarm.
SORE MEMBER
1 Post
[QUOTE=Gary Anderson]
BTW, the problem was due to lack of fuel pressure. He ran it out of gas at WOT! QUOTE]
That was yesterday I have to keep reminding myself to go back and read original post, easy to forget the facts.
SORE MEMBER
1 Post
SORE MEMBER
1 Post
Just found the installation sheet
Nitrous Oxide Systems
part #
15660 adj 4-7psi
15750 5psi
15680 adj 14-24 psi
15685 adj 25-50 psi
Normally open switches, about $37 jegs etc.
1/8" pipe thread
part #
15660 adj 4-7psi
15750 5psi
15680 adj 14-24 psi
15685 adj 25-50 psi
1/8" pipe thread
Thanks,
I would have more confidence in that over a $10 sierra part.
Gary
Gary
part #
15660 adj 4-7psi
15750 5psi
15680 adj 14-24 psi
15685 adj 25-50 psi
1/8" pipe thread
part #
15660 adj 4-7psi
15750 5psi
15680 adj 14-24 psi
15685 adj 25-50 psi
1/8" pipe thread
Gary, I can feel the pain
Ijust did the same thing to my newly Procharger 454Mag.
The strange this was that I didn't lose a whole lot of power.
Just pulled my piston out this AM. I burned a hole thru #5 exhaust valve, tuliped what was left, cracked exhaust seat, started burning thru the pistion and scored the bore.
I'm gonna end up lucky because I can get away with just honing the cylinder.
Just sent my carb to Dean, so that will be the majority of this lesson $$$.
Mo
Mo
Crazyhorse
04-15-2003 07:55 AM
