Cyclinder Head Torque Spec 525sc
Im Redoing My Head Gaskets This Weekend,any Body Have The Torque Specs On A 525sc Engine?are They The Same As An Automotive 454?
Torque specs are based on the bolts, not the engine. So you can go to ARP's web site and get the torque specs for you ARP bolts, etc...
Im Am Going To Get New Bolts But I Thought With The Gasket Involved There Is A Certain Pressure That Needs To Be Applied To The Gasket Inorder For It To Seal Correctly?then If There Is To Much Pressure It Could Damage The Gasket,then There Is The Change In Compression Rations When The Gasket Is Not Torqued Correctly!i Could Be Wrong Though,thanks For The Input
2 Trick Rick
0
09-28-2006 03:49 PM
