oil filter for 525 efi
Re: oil filter for 525 efi
What is the diference between the 51060R and the 51069R? I called NAPA and they didn't have the 51060R's in stock but recommended the 51069R. Is is a shorter filter and if so will it work?
Originally Posted by Hydrocruiser
Oil Filter f/ most Mercruisers
FYI:The thread type on the filter is 13/16-16.
Fram: PH5, HP4, DG5, PH13 (no anti drainback) Pureolator: L34631
Purolator Pure One: PL34631
AC: PF1218, PF932
Motorcraft: FL-12A
NAPA: 1060, 1060gold
Wix: 51060
Wix Racing: 51060R, 51061R R= Racing
K&N: HP3002
Baldwin: B1428 (Top Rated)
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Mercruiser: 35-802885Q
Mobil 1: M1-302 or M1-111
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
AC: PF1218, PF932
Motorcraft: FL-12A
Wix: 51060
K&N: HP3002
Amsoil: SDF-24
Hastings: LF279
Fleetguard: LF3679
Kendall: K31
Penzoil: PZ45
Quaker State: QS5
Shell: S63, SH38
Texaco: T38, T38B
Warner: PH1218
STP: S01218
Valvoline: V056
Forum Regulator
The only time you want a shorter filter is when you have those idiots that design the bottom of a GM truck that put the oil filter right on top of the front drive shaft, and with extreme axle travel it will kink the filter.
NAPA: 1060, 1060gold this one works perfectly...
ttt...it's time to do my first oil change on my new 525's. What's the most current thinking on the best filter to use?
I have been using the Purolator Pure One my 496's and 502 before that. Is the NAPA or Wix higher rated?
Also, what is the difference in the two Wix's filters listed above?
Forum Regulator
