Marine Lubrication
#1312
Here you go. AMSOIL Dominator 15w-50 Race Oil. I can get it for $8.10 a qt or $92 a case plus shipping.
https://www.amsoil.com/storefront/rd50.aspx?zo=1132530
AMSOIL Dominator® Synthetic 15W-50 Racing Oil (RD50) provides superior performance and maximum protection in high-performance and racing applications. Formulated to withstand the elevated RPM, high temperatures and shock-loading common to racing applications, Dominator Synthetic 15W-50 Racing Oil delivers superior performance and maximum protection in extreme conditions.
See Pricing Information or Place an Order
Package sizes include:
1-Quart Bottle
1-Quart Bottles (case of 12)
1-Gallon Bottle
1-Gallon Bottles (case of 4)
55-Gallon Drum
PRODUCT DESCRIPTION
AMSOIL Dominator® Synthetic 15W-50 Racing Oil (RD50) provides superior performance and maximum protection in high-performance and racing applications. Formulated to withstand the elevated RPM, high temperatures and shock-loading common to racing applications, Dominator Synthetic 15W-50 Racing Oil delivers superior performance and maximum protection in extreme conditions. Its shear-stable formulation was engineered to provide maximum horsepower without sacrificing engine protection. Dominator Synthetic 15W-50 Racing Oil provides straight-grade protection in a multi-grade formulation.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API-qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
MAXIMUM DURABILITY, MAXIMUM WEAR PROTECTION
AMSOIL Dominator Synthetic Racing Oil features an additive package heavily fortified with zinc and phosphorus for superior long-term wear protection. Designed for maximum durability, it ensures critical engine components are protected for the duration of the race. Dominator Synthetic Racing Oil’s superior additive technology provides unmatched durability in extreme conditions. In addition, its high levels of zinc and phosphorus additives make it ideal for street rods, muscle cars and other vehicles with flat-tappet cams.
SUPERIOR PERFORMANCE
Dominator Synthetic Racing Oil’s proprietary friction modifier provides reduced friction for maximum power and cooler engine temperatures, resulting in improved lap times and longer-lasting equipment.
PROTECTION FROM STARTUP TO THE CHECKERED FLAG
Dominator Synthetic 15W-50 Racing Oil’s multi-viscosity design provides maximum protection in temperature extremes. Dominator Racing Oil offers excellent coldstart protection and provides less drag when engine oil has not reached stable operating temperatures. It maintains superior film strength during high-temperature operation on the track.
SUPERIOR-QUALITY OILS, NO DISCRIMINATION
Many oil companies produce specialty racing oils for elite groups and do not offer them to the general public. For instance, several popular oil manufacturers produce racing oils offered only to NASCAR racers. All AMSOIL synthetic motor oils are already formulated to a higher level of performance than competitors’ oils, and AMSOIL Dominator Synthetic Racing Oil is no exception. It provides maximum performance and superior protection to all racers, regardless of their level of competition. The same AMSOIL Dominator Synthetic Racing Oil that is used in the engines of AMSOIL corporately-sponsored racers, including Scott Douglas and Brady Smith, are available to everyone.
APPLICATIONS
AMSOIL Dominator Synthetic 15W-50 Racing Oil is recommended for high-rpm, high-horsepower, turbo/supercharged, gasoline- or alcohol-burning, nitro-fueled or nitrous oxide gas-injected applications operated under severe conditions.
Applications include, but are not limited to, the following:
• Asphalt Late Model • Dirt Late Model • Modified Big Block • Ford Crate Late Model • Dodge Crate Late Model • Endurance • Rally • Sprint • Truck-Pull • Aluminum Block • Marine • Other high-performance racing and street applications requiring 50-weight oil.
AMSOIL offers WIX Racing Oil Filters for racing applications. WIX racing filters are specially designed for racing applications only.
TYPICAL TECHNICAL PROPERTIES
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 17.5
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 119.6
Viscosity Index (ASTM D-2270) 162
CCS Viscosity (°C), cP (ASTM D-5293) 6695 (-20)
Pour Point °C (°F) (ASTM D-97) -36 (-33)
Flash Point °C (°F) (ASTM D-92) 234 (453)
Fire Point °C (°F) (ASTM D-92) 248 (478)
Four Ball Wear Test
(ASTM D-4172B: 40 kgf, 75°C, 1200 rpm, 1 hr), Scar, mm 0.47
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 8.0
Shear Stability Kurt Orbahn (ASTM D-6278), % viscosity change 90 cycles. 6.3
High-Temperature/High-Shear Viscosity, 150ºC, 1.4x106s-1, cP (ASTM D-5481) 5.4
1-Quart Bottle
1-Gallon Bottle
55-Gallon Drum
PRODUCT DESCRIPTION
APPLICATIONS
Four Ball Wear Test
#1313
1-Quart Bottle
1-Gallon Bottle
55-Gallon Drum
PRODUCT DESCRIPTION
APPLICATIONS
Four Ball Wear Test
1-Quart Bottle
1-Gallon Bottle
55-Gallon Drum
PRODUCT DESCRIPTION
APPLICATIONS
Four Ball Wear Test
I need to know what the ZDDP and Phosphate and Moly and Calcium and Boron levels are.
@ $10.70/qt... i deserve to know before I buy in!......
#1314
Hydrocruiser,
How do you feel about mixing the Silver Cap 15w-50 with the 20w- 50 V twin? I was thinking of doing this to save some $$. I am running twin 540's, right around 600hp.
#1315
You've got what, probably at least 20K in engines, let alone the boat, and you're worried about 10-20 bucks? Whats wrong with this picture????
#1316
Well whats wrong with the picture is the economy is in the crapper, and premium is $5.00/per gal on the water. When I bought the boat and did the engines times were different. Now I barley have two nickels to rub together.
If you can't answer the question, or have something helpful to say, please keep your thoughtless comments to yourself.
Thanks Hydro and Mental, I am going to give it a shot. I figure I should save about $40 a change, over straight V-twin.
#1319
#1320
Ken
