Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 12-22-2008, 07:14 PM
  #1441
Hydrocruiser's Avatar
Arrow
Originally Posted by Rage
Hydrocruiser,
More generic then. The Redline oil analysis's which were less than optimum, what area(s) was(were) the shortfall? Wear, viscosity,other?
There were a few I saw at www.Bobistheoilguy.com posted under UOA's.
The iron and lead numbers on a few were higher than expected. Iron is cylinder wear and lead is from bearings.
Hydrocruiser is offline
Old 12-23-2008, 11:35 AM
  #1442
Rage's Avatar
I filled out the Redline web site's oil recommendation questionaire describimg my marine motor and usage. They recommended their 10W40 "or 15w50 if oil pressure is an issue". An interesting side comment offered was that minimum oil pressure should be 10 psi per 1000 rpm's. With 48 psi (hot) at 5800 rpm's I am falling way short of that.
Rage is offline
Old 12-23-2008, 12:36 PM
  #1443
Rage's Avatar
Thanks!
Rage is offline
Old 12-23-2008, 03:23 PM
  #1444
Arrow
Thanks!
I'd look into NEO and Torco as well as Motul. One or both use ester base-stocks last I checked.
http://www.neosyntheticoil.com/
http://www.torcousa.com/product.html
We "heard" Merc uses Torco in it's big drives...
I personally have found that mixing 50/50 M-1 EP 15W-50 with Motul 15W-50 gives outstanding wear numbers. Just pour in half of each and let the eninge mix it up.
Old 12-23-2008, 08:57 PM
  #1445
Rage's Avatar
Thanks Hydrocruiser for the additional options to consider. I am a little hesitant on these last two since they seem at first blush to be more oriented toward racing oils. I don't see myself in need of a pure race oil. How would one become knowledgable about their oil's performance in a marine engine that spends very little time at WOT?
Rage is offline
Old 12-24-2008, 01:39 PM
  #1446
Arrow
With your operation considerations the best oil for you may be M-1 15W-50 Siiver Cap with 25-30 hour changes.
I think it is a GRP III/IV Blend with lots of ZDDP. Excellent stuff at $ 6.00/qt at Wally Land.
Old 12-26-2008, 10:56 AM
  #1447
Rage's Avatar
Maybe you are right.
Rage is offline
Old 12-31-2008, 05:40 PM
  #1448
Rage's Avatar
I saw the M1 Silver Cap in Wally World today. $6.27/qt. If you want the gallon it is $26.00 or $6.50/qt. The bottle is labled "FULL SYNTHETIC". I wonder what that is the code for in the symantics of the retail oil industry ???????????
Sorry. I woke up feeling like being a little pissy today.
Bill
Rage is offline
Old 12-31-2008, 08:07 PM
  #1449
Mentalpause's Avatar
Bill
Are those gallons or 5 quart jugs? I thought they were 5 quart jugs.
Mentalpause is offline
Old 01-01-2009, 01:52 AM
  #1450
Bill
"Full Synthetic" is not "100% Synthetic". It is a highly refined petroleum product with synthetic base stocks and additives blended into it.
07DominatorSS is offline
Quick Reply: Marine Lubrication
