Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 06-27-2009, 05:40 AM
  #1651
what about Valvoline VR1- 40W, and a K/N 3002 filter, basically stock 502, should I use the 10 qts that I have remaining or use it in the truck.
Pete280 is offline
Old 06-27-2009, 10:55 AM
  #1652
Well the VR1 isn't a bad oil, it's not comparing apples to apples. The VR1 is not a synthetic oil like Amsoil is and based on the facts of the oil content the Amsoil is going to last longer and do a better job of protecting for whatever amount of hours you have your oil in your engine for. The valvoline will break down a little faster then the Amsoil 20/50 or 10/40. The K & N filter isn't bad if you like stuff made over seas, vs. stuff made in America! Let me know if I can help you out any more.
http://www.valvoline.com/pdf/VR-1_Racing_Motor_Oil.pdf
http://www.amsoil.com/storefront/aro.aspx
Racerngr1 is offline
Old 06-29-2009, 06:56 AM
  #1653
Not Right, the valvoline is ok stuff, I personally would use the 20w50 over the straight 40 for two reasons, better film strength when hot and faster oil pressure when cold.
Zinc levels are more than enough, you will change your oil before the zinc issue becomes an issue.
I would't worry about the TBN numbers, the fuel purchased today is very. very low in sulfer. Flash point, your Valvoline is good to 470+ no worry, if your oil temp is 470 you will have other major things to worry about, pour point who cares, it's a boat, water is pretty hard at 30F.
My 2 cents.
Ken
minxguy is offline
Old 06-29-2009, 08:03 PM
  #1654
Thanks, I'll switch to some 20/50, btw, I took a look at my K/N filter and it does say made in USA, if we still consider California parts of the US.
Pete280 is offline
Old 06-30-2009, 01:31 AM
  #1655
I believe that the K & N filters are now being made overseas where as they used to be made here; however, I may be mistaken and if I am, I apologize.
Old 06-30-2009, 09:18 PM
  #1656
Hydrocruiser's Avatar
Arrow
[QUOTE=Kidnova;2897665]
Originally Posted by Hydrocruiser
I ran the M-1 20/50 V-Twin in my ZZ502 for 4 seasons, with plenty of hard run time. The engine was torn down at about 140 hours and the builder said the internals looked great. So I'm a believer in the V-Twin.
The ZZ502 is now a "ZZ557" with about 200 more HP than before. The M1-V-Twin is a PIA to find. Would the Mobile 1 silver cap in 15/50 be a good choice/substitute? I change oil/filter every +,-20 hrs.
With 20hr changes SilverCap would probably suit your needs. The base content and zddp levels are a bit lower I think. But still good stuff. Certainly better than dino oil.
Hydrocruiser is offline
Old 07-04-2009, 09:53 AM
  #1657
Originally Posted by 07DominatorSS
Compare them yourself. The data sheets for both products are available. Take a minute and look at both of them. For one example, the AMSOIL grease and 10w-30 beat their products in the 4ball wear scar test by almost half the wear. There are other categories too, but that is just one of them. I'm not saying its a bad product, but, for the price, AMSOIL is just as good, and half to 2/3 the cost.
I have news for you, the 4-ball wear test is a gimmick. Has no relevance to what goes on inside an engine. It's been discussed at length on bobistheoilguy.com. It's used as a pre-screen to test additives.
MikeStaz is offline
Old 07-04-2009, 07:43 PM
  #1658
Arrow
It's called marketing.
But they do compare 4-ball results to their competitor's products and if they are "ahead" sometimes... as you mention it... may indicate at least a stout anti-wear additive presence in their oils? That could be good?
Old 07-22-2009, 04:46 PM
  #1659
bck
Charter Member#568
bck's Avatar
What about custom blend oils? Haven't seen any info on that. I have access to someone who says he does custom blends for people and has been doing it for years. What can these people do and what would the be the ideal oil if he could do whatever you wanted?
Straight bottoms and flat decks
bck is offline
Old 07-22-2009, 08:30 PM
  #1660
Arrow
So he's an "oiltender" of sorts...but never went to "oiltender" school?
All the mixing I need is done at my favorite pub.
To answer your question for example.....Mobil + Amsoil = Mobsoil (sounds like something that Capone' would use in the getaway car).
Quick Reply: Marine Lubrication
