Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 12-31-2005, 11:52 PM
  #471
formula31's Avatar
Default Re: Marine Lubrication
Originally Posted by Hydrocruiser
IN a non-blower motor running rich can containate oil faster than many realize. In a blower motor the blow-by will put gas in the oil no matter if you run rich or lean...that's from the Sterling guys..
Sorry if I was unclear..
Hmmmm. I guess I need to drink more to understand that one.
formula31 is offline
Old 01-01-2006, 03:09 PM
  #472
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
..that is what I am told..not through experience if that helps..
...Hey we hit 10,000 HITS!!
Happy New Year 2006!
Hydrocruiser is offline
Old 01-03-2006, 11:24 AM
  #473
What do you figure is the best oil to keep flat tappet cams alive? Im not talking break-in. These are already seasoned but Ive heard the latest formulation dont have what it takes to keep the flat tappets alive. The suggestion was to run the GM EOS mixed in with the oil, all the time?
Use a good motorcycle engine lubricant. Spectro oil make petroleum, syn/petroleum blends, and full synthetics with high z & p numbersin a whole bunch of different viscosities. Using any of them your flat tappets will be fine. Ken
minxguy is offline
Old 01-03-2006, 06:52 PM
  #474
Synthetic 20W-50 "motorcycle labeled" oils are the best offshore engine oils ..period..
Old 01-06-2006, 04:44 PM
  #475
If you do not want to use GM's EOS and are using non-racing oil ..not too high in ZDDP and moly...Torco has a "break-in" lube you can add...it is loaded with moly and zddp. A builder in my area uses it for assembly...but you can add it in too.
Old 01-06-2006, 09:06 PM
  #476
www.joegibbsracingoil.com.then click "products"
jpclear is offline
Old 01-07-2006, 04:41 PM
  #477
That stuff is high in zddp and moly..especially the synthetics...
...Also found out the Flat Tappet guys like Redline 20W-50 for that reason as well...tons of moly and zddp
AFter a couple years of being in the oil business my conclusion is the racing guys use a good base and lots of anti-wear additives...ZDDP and Moly are the ones that work...most of the rest are snake oil...Teflon...graphite...are worthless or destructive...Zinc..Phosphorous and Moly rule..and throw in sulphur for the drive as well....plus good detergents and good anti-corrosion agents for the marine environment...!!
Old 01-09-2006, 10:48 PM
  #478
Rob
Strip Poker 388's Avatar
Hydrocruiser I figured you might want to see this.I just tore down my motors for the winter and cut open the filters to see whats in them .This is the inside of a Wix eqivilant to the Fram HP6 which Sells thru Napa as a 1222R Napa/Wix racing filter.I measured the paper element stretched out it was 7.10 foot long.You can see the by pass and the spring that holds the cartridge in place .It kinda looks like a valve spring
What ya think?
Rob
Attached Thumbnails Marine Lubrication-chevelle-1-9-06-038-medium-.jpg   Marine Lubrication-chevelle-1-9-06-039-medium-.jpg   Marine Lubrication-chevelle-1-9-06-041-medium-.jpg
Strip Poker 388 is offline
Old 01-10-2006, 07:03 AM
  #479
What ya think?
Rob
I am impressed...now that's how a filter should be made right?
Old 01-10-2006, 07:33 AM
  #480
Rob
I would think the Fram HP 6 is made close to the same way?
Quick Reply: Marine Lubrication
