Marine Lubrication
#671
Re: Marine Lubrication
Is there a noticeable difference between v-twin and amsoil? I am running the amsoil lube in my drive and the price would be less for the amsoil because I paid the membership dues. But I would the extra if v-twin is better. Thanks.
#672
Just changed to M-1 15 -50 EP in my 496 HO's at 150hrs. I was running Torco 20-50 Racing and had a little lower pressure on the port motor after a hard run. When I fired up with the M-1,the pressure went right to 40psi and stayed there (cold). Even when run up to 2K rpm it stayed at 40 until I put a load on the motors then it went to 60!
Ran it hard and had more pressure than with the Torco and no reduced pressure after a run in either motor. I am a believer!! Thanks HydroC!
#673
It's also holding up very well in some uao's I saw in 525's that were run 50 hours...the TBN showed it had more abilty to keep going and the wear metals were almost zero.
May as well just use the A/C oil filter for $4.99 which is very good and then twins will be a $70.00 expense every 50 hrs. and you get maximum protection
It's better and less hassle than 25 hr changes with 40wt conventional Kendall..about $40/change...so the conventional is more $$..
#674
I wanted to report back after my switch to the M1 V-Twin. I'm running a mpi 5.0 SBC and was concerned about hot idle oil pressure. With the V-Twin, I've picked up 10# cold and about 5# hot. Maybe 2 or 3 # after a hard run. I'm running a NAPA gold (Wix) filter.
I still worry about fuel dilution (the oil still smells to me like gas) so I plan to do an oil analysis after about 25 hours.
#675
Hydrocruiser, What can you tell me about an AC 932 oil filter? Is it performance marine worthy? It appears to be similar in size to the K&N 6002.
#676
SORE MEMBER
1 Post
MI-302 filter failure.
HC, I was out boating last weekend and saw my oil pressure drop about 10 psi.
Went home and did an oil change, when I took the old filter off I found that the internal metal screen had partially failed and collapsed toward the middle.
New filter and pressure is back, thank God.
Are you aware of an address/department where I can send the filter to EM for them to have a look at it?
This is the first issue I have had in over 30 M-1 filters.
#677
I have been lately not putting as much emphasis on going to M-1 filters as we have had a couple such problems.
It seem the really big motors need big flow and Fram Racing; Wix Racing; Baldwin and K&N do a better job at this.
Mobil also changed the design of this filter over the last year...just like they have changed oil formulations...we are trying to keep up with the changes.
The oils such as 15W-50 M-1 EP are now better than the previous RedCap...I am not sure what they did to their oil filters but the older ones had a more sophisticated bypass valve.
My advice...try K&N...many offshore racers use them.
That is why it is worth a minute now and then to keep your noses in this thread...things change!
#678
SORE MEMBER
1 Post
Originally Posted by Hydrocruiser
Look back a few pages on this thread..Vandy is a big Mobil distributor...he can get the job done.
This was my last old style MI-302, installed a new style one. Will be taking a look at it every couple of trips. Probably will go with WIX racing same as we use on our race cars on the next change.
#679
Thanks for the reply, looks like Vandy021 hasn't posted since April.
I called Mobil today and they indicated they are being used in higher horsepower applications so they beefed 'em up.
Time will tell.
