Marine Lubrication
#882
Re: Marine Lubrication
Originally Posted by Hydrocruiser
If you ask the Amsoil guys who have a booth at OSO races they will tell you not to use the Universal Marine lube in an "offshore rig" but to use Severe Gear...I think the Marine product is nice for a runabout but too thin for offshore applications as well.
Asmoil made a mistake in my opinion of discontinuing their Series 2000 Marine gear lube. I know Teague liked it a lot as did Imco.
Go with this stuff below is my call as it is what your drives need...High Pressure Lube Additives..aka ZDDP and plenty of it.
Severe Gear seems to be a cut above the green stuff.
https://www.amsoil.com/storefront/svg.aspx
Ah, just one more thing to contemplate over the winter.
#883
Compare the specs:
AGM - https://www.amsoil.com/StoreFront/agm.aspx?zo=1132530
SVG - https://www.amsoil.com/StoreFront/svg.aspx?zo=1132530
#884
Originally Posted by o2man98
Actually, the AGM Marine Gear Lube is a thicker than the Severe Gear 75w-90 when cold (40C). The main difference that I see is that the Severe Gear has a VI of 163 vs. 130 for the Marine Gear Lube making the SVG become the thicker of the 2 warmed up (100C).
Compare the specs:
Compare the specs:
#887
After going around in circles on marine gear lube I don't think you can do better than Mobil-1 75w-90. The only thing it dosen't have is the word "marine" on the package.
#888
Originally Posted by Rebel_Heart
How is the Mobil 75w-90 different than the Amsoil products? Are you able to purchase the Mobil product in local stores?
#889
Originally Posted by cloudmaster_321
Would you prefer this over the merc high performance?
A good synthetic drive lube and showers will extend the life of your drive maybe 30% I have found in working with boaters in my area who used to use the factory product.
Ove-heating and bad seals typically are what cause premature drive failures.
#890
Kinda a rookie question i'm sure, but in the Mobil 15W-50, what exactly does the numbers stand for?
The multigrade oils' viscosity modifiers are long-chain molecules that lessen the change of viscosity with temperature variance. In the past, the polymer additives (used to thicken the oil) were sometimes susceptible to viscosity loss. Permanent viscosity loss occurred when high shear forces (such as the relationship between the main bearings and the crankshaft) actually break the polymer molecules into less-effective smaller pieces. On a similar note, temporary viscosity loss also occurred when the polymer molecules aligned themselves in order to create a path of least resistance.
Fortunately, today's synthetic oil and additive packages have improved oil's shear-resistance. However, oils with the same rating from different manufacturers can exhibit different viscosity ratings in an operating engine, depending on the shear stability of their viscosity-modifying additives.
This means not all synthetic oils perform alike and the same goes for conventional oil too.
