Marine Lubrication
#931
Re: Marine Lubrication
Originally Posted by Kidnova
Yep. The wife prefers synthetic ... less friction
#932
Originally Posted by Hydrocruiser
15W-50 pumps like a 10w...use it when it gets cold. V-twin is good down to 50*F. Much like a straight 40wt.
#933
#934
BTW, you can get the ° symbol by holding alt and pressing 0176. Or run "charmap" and insert it from there.
How do you determine what temp a particular weight oil is good down to?
#935
0w -30F
5w -25F
10w -20F
15w -15F
20w -10F
25w -5F
Hope this helps. Ken
#936
Originally Posted by Wobble
That sucks, They did say that the 10w40 and 20w50 vtwin motorcycle oils are still full synthetic. I switched from the 15w50 to vtwin when they reformulated for emissions over a year ago, didn't realize they had cut the synthetic content also.
#937
Originally Posted by Rage
Does this mean that with the exception of the noted 10w40 and 20w50 vtwin motorcycle oils all the Mobile1 oils are in effect "blends" of synthetic and petroleum base stocks?
#938
Originally Posted by o2man98
It seems that GC testing has shown the M1 EP 5w-30 and 15w-50, so far, to be mostly GRP 3 basestocks.
Ever since Mobil lost their lawsuit against Castrol (they objected to the fact that Castrol "synth" was made from Group III base stock instead of being truly synthesized), and the court decided that the word "synthetic" was related to oil performace, not exactly how it was made, most manufacturers of "synthetic" oils switched to using Group III base. Mobil 1 was one of the last holdouts.
#939
#940
This was posted on a site that tests synthetic oils:
