Oil pushing out dipstick on new motor?
Registered User
Originally Posted by articfriends
I mounted 1" pipes 8" tall in my valve covers,put pipe couplers on them on top and painted it all black,k/n 1 1/2 breathers clamp onto the tubes perfect and as cobbled as it sounds it looks good. When i reached 110 hours last time on motor it started to vent a little tiny bit of oil out breathers,i then rolled up scotch brite pads and inserted them in breather tubes to help seperate oil mist until i pulled motor and freshened it. Blower motors are real hard on ring seal,a vaccuum pump might help too but you better vent it to a puke tank with a drain,Smitty
If you click on the picture and enlarge it you'll see the vent tube right behind the blower inlet and right behind the innercooler tube coming frim innercooler to get get a idea of what i mean. The circle track racers been running tall breather tubes for years around here.
What charger and drive combination are you running?
