No water out exhaust >
Old 07-27-2005, 09:58 AM
racer-x6's Avatar
Default Re: No water out exhaust
Originally Posted by MILD THUNDER
My buddy who hooked the pump up swears he has it correct. I told him maybe the hoses are wrong, but he says with the new plastic one piece housing it can only go one way. It does seem to pump good water from the pump. When I disconnected the hose coming from it, a large amount of water was coming out at idle, its just that it was coming out in big "gulps". Big gulp, big gulp, big gulp.
I would check it . it's easy to mix them up. Put the water hose in the sea strainer block off the side going to the drive/outside of the boat and turn the water on full blast. it should pull the water down quick. Also as stated before check all the coolers after the pump for impeller blades.
racer-x6 is offline
Old 07-27-2005, 09:59 AM
Brad Zastrow's Avatar
The pump will suck air or water whichever is easier. SInce air is lighter... I have had this same problem. Fix the leaks and seal the system. Back flush as well.
Brad Zastrow is offline
Old 07-27-2005, 10:13 AM
Were doomed!
Wally's Avatar
the plastic housing on the seawater pump is labled for LH rotation. You have to look at the backof the houseing and compare it to which way the pully rotates. Theres an arrow and corresponding in/out lables on the inlet/outlets.....
If you pump happens to rotate the opposite way then installing the hoses on the pump according to lables would be backwards and thus wouldnt work.....give it a quick look to verify your buddy's work....just tell him you want to check for your own peace of mind before you go crazy looking everything else over!
-Wally
Wally is offline
Old 07-27-2005, 01:06 PM
Charter Member #71
DanB's Avatar
Either the hoses are on the sea pump backwards or the thermo is upside down.
DanB is offline
Old 07-27-2005, 04:09 PM
Fixed sea stainer and its all good now. Thanks guys, MT
MILD THUNDER is offline
Old 07-27-2005, 06:33 PM
Charter Member #71
DanB's Avatar
damn..wrong again.......glad you found it
DanB is offline
frankw32
4
04-18-2008 10:27 AM
frankw32
0
04-17-2008 07:36 AM
k24u
15
05-24-2006 01:07 PM
ratman
7
09-16-2005 07:36 AM
Chart
5
08-06-2003 05:52 PM
Quick Reply: No water out exhaust
