looking for BBC heads casting #990
1 Post
You probably already know GM does not make them. Unless someone has some laying around used your in luck. Other option is to go for merlins.
B-MAX REPAIR
I Have A Pair Of Cast # 14096188 New Valves Perfeft Shape. Not Sure If They Are The Same. Ron Bender 216-390-1330
![Talking](/forums/images/icons/icon10.gif)
posted on another thread GM does not make them but GM performance does or at least did GM and GM Performance are two separate operations
Originally Posted by ScarabScoundroul
I have 2 pair. 3 of them are cracked between the valves. Still interrested?
Thanks everyone i have plenty of cracked ones.
ScarabScoundroul how much for the one that is not cracked maybe this way i can make one pair for someone that needs a set.
i have decided to go with merlin heads. I am afraid that if this many are cracked their is a problem.
birdog are both of them cracked.
[QUOTE=guillermof]I have decided to go with merlin heads. I am afraid that if this many are cracked their is a problem./QUOTE]
Yep, and more than likely the problem is stock Merc risers/manifolds. That's what trashed mine.
