Alpha one upgrade
I'm upgrading a Alpha I gen one to a Alpha I Gen Two. The things I knoe I need to change are:
Outdrive
Complete gimble housing outside
Inner plate
What else will i need to change?
Shift plate
Exhaust "Y"
Coupler housing
Hyd. steering cyl.
Also I think the hole paterns the same, is this right
Thanks for you help.
Outdrive
Inner plate
Shift plate
Exhaust "Y"
Coupler housing
Hyd. steering cyl.
Originally Posted by GOODT
you are correct the only thing that you will need to add that you didnt mention is a drive res bottle
Shift plate
Exhaust "Y"
Coupler housing
Hyd. steering cyl.
OR NOT
No You Dont Need To, All That Should Be The Same
YOU DON'T HAPPEN TO HAVE A GOOD USED SET-UP DO YOU?
No Sorry But You Can Try Calling Paul At 410-855-5656 At Haurbor North Marina He May Just Tell Him Joe From American Performance Told U To Call
THAT # IS NOT IN SERVICE
ERIC
![Talking](/forums/images/icons/icon10.gif)
If you do the swap, make sure the speedo hole in the new transom assembly has a plug in it. Would hate to see you hose your engine bay down with salt water. Unless your going to use it.
BadDog
9
09-09-2004 02:36 PM
