Oil temp or oil pressure - gauges?
Looking at possibly redoing my dash this winter (if we keep the boat) - I have a bit of room to move things around, but I'm wondering what you feel is the "minimum" amount and type of gauges, and what you would add if possible.
Boat is a 29' twin, stock Merc 330 hps. Will not be upgrading power, this boat will stay with standard, start every time Merc black motors.
Thanks!
Thanks!
SORE MEMBER
1 Post
Min. amount would be tach, oil pressure, water temp. desirable options would be oil temp, fuel pressure, water pressure. IMO
I agree, Tach, water temp, oil temp, oil pressure, water pressure and volt gauges. Oh yeah, and those 2 cute little lights that glow and say "WARNING....WARNING!!!!!"
Originally Posted by formula31
vacuum
they were installed by the previous owner. i think it's more important to know when an impeller is about to fail.
Hydro, straight V hull, no step on this boat! ![Smilie](/forums/images/smilies/smile.gif)
Fred, I was already out on your site pricing the gauges - if I go ahead with this, I'll be calling you for some advice. I hear you've replaced a gauge or two in the past...
![Wink](/forums/images/smilies/wink.gif)
Originally Posted by vette131
i have a couple gafrig vacuum gauges im taking out of my cig & replacing them with water pressure if anyone wants them.
they were installed by the previous owner. i couldn't find a use for them in a boat.
wasn't trying to start anything. big cams equal low vacuum at idle. get on plane & they hardly have any vacuum due to engine load. as far as being clueless i doubt it. i've been a ford tech specializing in drivability & electonics for 20+ years.
like i said wasn't trying to start anything, i just think if you have limited room for gauges, vacuum would not be on my list.
