Throttle Position Sensor
Half a volt, .5 to 4.5 volts, I've seen it as low as .1 to a high of 5.25 and still be in range.
It's a pretty standard spec.
Charter Member #34
Thanks very much guys, I do appreciate the quick responses.
Trippin,
Is your Avatar the 41 Velocity that is now up on Lake Norman?
Trippin,
Charter Member #601
Whats up Doc??? Having some problems? It has been too long since we talked.. I'll be calling you in the near future. How are bearing supplies holding up??
Dick
Dick
Charter Member #34
Dick
Dick
I've had you on my mind and have been planning to call you.
Was up at the Leopa Run weekend before last and man, I did not know you were such a legend up there.
If the word "Outdrive" comes up your name is the next thing to follow.
I sent Roger C. aka "RHC" your way, hopefully he called you.
The bearing supply is pretty good right now. Things have improved with Timken.
Send me a BIG order. I need fuel money!!!!!!!!!!!
Dock
seafordguy
3
03-12-2008 01:53 PM
