Water pump failed or cloged?? >
Old 08-08-2005, 11:51 PM
FOUNTAINATLAST's Avatar
Default Re: Water pump failed or cloged??
Give Don at TP Marine 602-438-1361 a call, he has a wide varity of strainers and can get you set-up pretty reasonably.
FOUNTAINATLAST is offline
Old 08-09-2005, 08:10 PM
Swede's Avatar
My sea strainers have a one way overflow valve. A few weeks ago the spring broke in this valve and the valve stuck open sucking air. Needless to say it made quick work of my impeller as soon as I slowed down.
Swede is offline
Old 08-10-2005, 07:05 AM
I took it apart. The pump is like brand new. Sea weed was clogged right in the intake of the pump. I back flushed everything and now i am going to buy some sea strainers asap. anybody have a preference, i noticed on here they have them with dual intakes and dual outs, can i usse this to only have one for both engines? How about the cheap $20-40 ones i see that are plastic, would these work or not enought flow? I see some are like $400
Mike L is offline
Old 08-11-2005, 06:25 AM
Pwrbt33's Avatar
Talking Re: Water pump failed or cloged??
Great to hear that you found the problem. Gaffrig makes a nice universal one. I would use 1 sea strainer for each engine unless you have one custom made. I know some Fountains only use one but thats on a 42' w/1050 sterlings in it.
John S.
Pwrbt33 is offline
Old 08-11-2005, 06:30 AM
GOODT's Avatar
Check Out Rex Marine, Eddie Marine, Or Imco All Three Make Really Nice High Flow Strainers
GOODT is offline
Old 08-11-2005, 12:41 PM
PatriYacht's Avatar
I bought a couple of Gils from Trick Marine for about 200 ea.
PatriYacht is offline
BillR
11
07-29-2022 06:31 AM
HP500Hammer
15
01-30-2008 06:03 PM
jdub
7
03-26-2007 05:06 PM
Jayl13
15
01-17-2003 03:17 PM
Quick Reply: Water pump failed or cloged??
