Procharger M-1 7.4MPI 5#PSI softening
This is my first season with a used M-1 (5#psi) installed on my used 7.4 Mpi (600hrs). I have 125-135#'s compression in 1,2,7,&8 and 110-1153s in 3,4,5 & 6. I squirted oil in all the cylinders and found aproximately a 10# increase in all cylinders. The leak down however is 50#s/ 80#s in 1,2,7,&8 and 20#s in 3,4,5 & 6. I can hear leak in the exhaust. I also have oil backing up the dipstick under full power. I plan to pull the heads and re-work if necessary, replace the factory gasket with better gaskets designed for blower applications and re check the leak-down to eliminate gasket and valve leaks. If I still have leak problems I will tear down further to the pistons and rings. I was planning to hone, re-ring and replace the pistons with forged pistons. Any suggestions for pistons/rings. If the bearing surfaces are good is it worth the expense to replace rods? rod bolts? and go to a steel crank? I plan to stay with 5#s of boost and keep my rev limiter @ 4750 RPM. The application is a Bravo III on a heavy cruiser.
Oil up the dipstick is caused by blowby, too much for your breathers to handle. If you are running 50% leak down you have some major problems. As for what to use on rebuild. replace rod bolts, go with forge pistons (there are some off the shelf dish pistons avabile for this motor in the 8:1 ratio area. I have had motors in past with the above rods & crank with no problem.
