View Poll Results: I replace the following when refreshing my motors
Just a valve job
4
10.81%
valve assy, cam and rockers
3
8.11%
complete valve assy and piston rings
7
18.92%
complete valve assy, pistons, bearings, cam, etc..
23
62.16%
Voters: 37. You may not vote on this poll
Refreshing Motors
Registered User
Re: Refreshing Motors
I dont know what the time limit is, but the only way I know how to do a leak down test is by removing the spark plugs and rolling the crank on its compression lift, holding it there for x number of minutes to check the seat of the valves and the seat of the rings... This is done with a gauge in place of the spark plug. Do this eight times.
Am I close guys to marine applications??
Originally Posted by mobilecal
so you typically rebuild every other what?? 200hrs??
P.S.-I bought a leakdown tester at local carquest for 50$,you need to roll cyl on tdc with plugs out,screw gauge in,adjust regulator to set gauge at 0 and open valve and watch gauge,its simple,it just takes a little time.
Registered User
Originally Posted by articfriends
my blown 502 i ran 185 hours which was anout 30 hours too long,it was burning oil and leaking oil bad towards the end. my 540 had pretty good leakdown results(under 10 %) at 90 hours but at 138 hours had several cylinders at 35% and one at 70%. The boat still ran good but was starting to puff a little oil when i started it up. It had also lost 1 1/2 mph at wot. The bearings looked like new but valve job was shot,head gaskets were almost burned thru wire ring.timing chain had chips in the rollers and the cylinder that had 70% leakdown had a intake valve that was sawing thru the guide.If I had tryed to run it a 3rd season it would have blown up in middle of boating season. A normally aspirated stock motor would be a whole different story,I would do a leakdown annually and watch oil pressure,when it started to lose cylinder seal it would come apart at that pont other wise i would just watch to make sure it didn't smoke on start up,tick or lose power,Smitty.
So 200 hours would have been fine for you if you had a NA motor...Did you build the motor yourself?
Registered User
what did the coating cost you?/
was the torque plate something you made or ordered. I was just wondering what the tolerances were on the plate's. Did you achieve the .0002 with your plate?
The coatings cost 58$ per piston plus s/h there and back(roughly 500$) I also sent the cylinder heads to swain tech and had chambers and exhaust runners coated(another500$). The local machine shop has a bbc torque plate and modern hone,the cyllinders were less than .0005 out of round but remember if your measuring them at home after having honed w/torque plate they won't be as round as when they were w/plate on. I mainly look at piston to wall clearence,not roundness after having cyl honed w/plate,Smitty
Registered User
Ive never installed the zero gap rings before, is there a technique to installing them. They cant be as easy as your gapped rings.
Also did the machine shop give you the torque sequence in attaching and removing the plate?
Did they use their bolts or yours?
