Mods for my low performance (310 hp) 454 >
Old 08-22-2005, 01:10 PM
  #31
Whiteknuckle's Avatar
Default Re: Mods for my low performance (310 hp) 454
Unitek,
I just don't think you are going to like the Bravo on that boat. I think it will give you to much stern lift. I would suggest sending your 25 Mirage to Throttle UP, BBlades, or Houston Propeller and tell them your problem. Let them work it over, and you will be amazed at the difference. Is you outdrive trimmed all the way down? Does the boat have tabs you can drop and help it out of the hole?
Also, I respectfully disagree with Pat McPherson, I would not hesitate to twist that engine up to 4800-5000 RPM if you are not restricted by a rev limiter.
Whiteknuckle is offline
Old 08-22-2005, 01:12 PM
  #32
I hope you were kidding about the laughing gas. Stay away from that stuff!!!!
Old 08-22-2005, 01:29 PM
  #33
Pat McPherson's Avatar
Originally Posted by Whiteknuckle
Unitek,
No problem with running the engine up to 5000rpm but it will make max power at more like 4500rpm...
And Yes, the rev limiter should kick in at 4800...
Like I said earlier the low power 454s/7.4s have VARY mild cam shafts...
Both my 24' Pantera with a Gen IV 330HP and my 24' Super with the Gen VI 310HP ran faster with bigger props at 4300-4500rpm than at 4600+rpm.
From my experience these engines pull nice to about 4200rpm then die out...
Change the cam if you want to make power up to 5000rpm...
Patrick
Pat McPherson is offline
Old 08-22-2005, 01:46 PM
  #34
I have a 5.0 Mustang with a Vortech, alk/meth injection and NOS... Power adders are my nature. Im just gonna call some of these prop places and see what they say.
Unitek is offline
Old 08-22-2005, 02:19 PM
  #35
If You Find You Need A 23 M Plus I Have One Less Than 10 Hours Not A Mark On It $250.00 Ground Ship Included
Badtoon is offline
Old 08-22-2005, 03:01 PM
  #36
I kinda like the way the 24P Bravo prop sounds. I would like the extra handling and improved holeshot and mid range. Where are you from Badtoon ?
Unitek is offline
Old 08-23-2005, 05:13 AM
  #37
Charter Member #655
dyno's Avatar
if you want to go deep I have a set of rods and pistons that are +.030 that will get you to 9.5/1 I'll sell you cheap! 616-403-4482
Don
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 08-23-2005, 07:06 AM
  #38
Watkins Glen NY on Seneca Lake. Finger lakes Region
Badtoon is offline
Old 08-23-2005, 09:43 AM
  #39
Dyno,
What kind of stuff is it and how much money we talkin ? send me a pm
Mike
Unitek is offline
Lt for Life
Baja
0
06-07-2006 04:36 PM
BUIZILLA
6
03-07-2005 07:57 AM
David Haag
66
12-10-2004 09:22 PM
BUIZILLA
6
10-11-2004 01:04 PM
JO - PANTERABOATS
Pantera
11
04-17-2003 12:19 PM
Quick Reply: Mods for my low performance (310 hp) 454
