1999 502/brovo 3 stalling in reverse >
Old 08-28-2005, 09:09 AM
Default 1999 502/brovo 3 stalling in reverse
when i shift from netural to reverse my motor stalls. not all the time but usally when i'm trying to dock next to a very expensive boat! it's getting to be a pain in the rear. yesterday i had a nice audiance at my marina while docking. of course it stalled and i almost hit another boat. thank god there was somone up front to stop the collision.thanks for any help....james
MariahMadness is offline
Old 08-28-2005, 09:25 AM
CMG
CMG's Avatar
Default Re: 1999 502/brovo 3 stalling in reverse
carb or mpi?
Chris G.
CMG is offline
Old 08-28-2005, 01:23 PM
1999 502 mpi
Old 08-30-2005, 06:44 AM
anyone?
Old 08-30-2005, 07:15 AM
Pwrbt33's Avatar
Talking Re: 1999 502/brovo 3 stalling in reverse
I would have a tech check out the engine functions with a DDT. Sounds like the IAC isn't working very well. How does it do in FWD, does it ever stall?
John S.
Pwrbt33 is offline
Old 08-30-2005, 07:29 AM
CMG
CMG's Avatar
if it were carb I would have startered there with low idle or something simple
Chris G.
CMG is offline
Old 08-30-2005, 10:34 AM
Jerry B
I could be all wrong but I thought I heard or read these things have a switch that mementarily drops rpm when shifting to help prevent gear damage. If this is true could shift linkage or the switch be out of adjustment? Maybe someone else knows more about this.
Good luck.
Jerry.
Jerry B is offline
Old 08-30-2005, 09:14 PM
GOODT's Avatar
jerry this is true with a drive that uses a clutch dog such as an alpha but the bravo uses what is known as a cone clutch and for the most part does not need a shift interuptor
GOODT is offline
Old 08-31-2005, 10:39 AM
Jerry B
Joe;
Thanks for the clarification. I did'nt no for sure. You never know where you might find an answer.
Thanks.
Jerry B is offline
DONZIMAN97
9
05-17-2004 07:59 PM
nitro/max
2
05-29-2003 08:54 AM
baja bailey
10-22-2002 02:48 PM
Quick Reply: 1999 502/brovo 3 stalling in reverse
