Amsoil Products
Re: Amsoil Products
I'm quite happy I started this thread, there seems to be some good info. I do run AMSOIL in my dirt bike and have had zero problems, was thinking about possibly running it in the drives, Seems a few of you like Mobil products also.
Re: Amsoil Products
Re: Amsoil Products
i buy all my Amsoil at dealer cost .20w50 is about 6.50
it only cost 20 bucks a year to be a dealer.
and i really like the new marine gear lube , was'nt sure at first :
Re: Amsoil Products
amsoil has had ext drain intervals for years and years.
'bout time mobil got it(still not as long as amsoil though)
as for price royal purple is way higher $$$$$$$$$$$$$$$$$$$$$$$$
Re: Amsoil Products
I also was wondering about the marine gear lube????
Re: Amsoil Products
Originally Posted by Hydrocruiser
Now that Mobil-1 20W-50 (V-Twin) is $6.99 @ Walmart if you need a premium 20W-50 the price is hard to beat..last year the cost was $8.99/qt which is still about the cost of a similiar Amsoil or Redline product....plus shipping in many cases. At least with Redline you get a heftier ester content for the 9 bucks if you decide to spend that much.
Mobil-1 Extended Goldcap products are $ 5.45 in 5-qt containers at Wallyland as well. That's a good value.
20-50 motor oil
20w-50 motorcycle oil is $6.90 also
motorcycle oil
fyi
Re: Amsoil Products
Having said all that... Amsoil 4-cycle oils are generally good and they get better as the price goes up. They range from $6.00 to nearly $10.00/qt.
All are better than conventional products for certain.
i don't see anything above $9.00
amsoil motor oils
most were $8.75 and down with 25,000 drains.
although ii would'nt go that long
usually 15000 to 20000,
when is the other companys drains
mobil??????????????
Re: Amsoil Products
.....hold your horses..I edited my previous remarks too...I was off a buck..sorry ...and ... I have advocated using $7-$9/qt oil as I do regularly...and you do get an added benefit from the stuff too.
Re: Amsoil Products
If you guys really want the best try Swepco. We have been using now for over a year. less friction and wear on motors, hp increases and no engine problems. Nortech is using it exclusively on all their motors, no failures. It really is that good.
