Exhaust Gaskets Blown
I've been using the adapter plates to use emi manifolds on ford heads. Everything was good for about 30-40 hrs, now the gasket between the adapter and the manifold is leaking. I was going to use a header type copper gasket for replacement. I think the adapter is really heating up and cooking the stock gaskets that I got from emi. Fred(trick) If your lurking,please chime in. Thanks ,Lance
