on engine still overheats at wfo..any ideas
no bravo drives, i have ssm #3 drives bw trans, no eng water pump, just raw waterpump. no thermastats crossovers one engine is perfect, the other runs 20* hotter all the time and is ok to 4k rpm but starts climbig when i run it wfo. engines were dyno had .52 bcfc . only did is one engine has the power steering cooler and thats the one that gets hot but he cooler is clera the other coolers are new
It was asked but not answered. Do you have water pressure gauges? This is a must check item at this point. If you don't have them, get them.
If you have engine flushes make sure the check valve isn't clogged. I've seen this many times and it's easy to overlook.
Masher touches my
It doesn't surprise me, I've read countless threads where people have cooling issues with crossover tubes. Do a search and you'll get some more ideas. Good luck.
You have a restriction somewhere. You need to find it before something bad happens. Start swapping parts or measure the pressure at various points along the waters path.
both engines are set up the same one runs nice and cool it's twi is getting hot!
![EEK!](/forums/images/smilies/eek.gif)
![Evil](/forums/images/smilies/evilB.gif)
Rat ... pull the Thermo ......I agree with the other guys ....good place to start .... ..and they do hang ..even new ...
