A question about compression ratios
Re: A question about compression ratios
exactly right, if they are deep dished or sitting way down, then it may be best to get new ones as a ratio that low wouldnt be good fo an n/a motor.
What I'm really trying to figure out is if I were to keep the quad rotor setup and go to some chevy heads, could I get away with not changing the pistons. That way, it would be all bolt-on and I wouldn't have to pull the engines. If JC didn't have his head stuffed so far up Masher and Stecz's azzes and would call me back it would be alot easier to figure out.
not for nothing OLDSCHOOL but those engines look awesome in there . I have flycut some conventional pistons to use with big chiefs but never the othe way around the only thing I see is that all the other heads are going to be larger in volume and the piston you already have is going to bring the comp down too far . Good luck to you Laz
