Head advice on BBC
#32
My wife shot down the new heads. I need to keep my cost down. I have been looking at different casting numbers for large ovals and have found a lot of conflicting information on chamber volumes. I am looking for a head with 105 to 110 cc chamber with good flow. Anyone have any suggesions, my machinist has a set of 3993820's and 353049's. His book shows smaller chambers than mortec.
Thanks,
Jeff
Thanks,
Jeff
#34
These inconel exhaust valves...how important are they? I recently had a local engine builder do me a 502, 8.5:1 with a hydraulic roller 535/554 lift but I don't think I have those valves. Was this a terrible mistake?
#35
Inconel you ask?
Let's put it this way. I have seen enough failures on marine engines that didn't use Inconel exhaust that I wouldn't build a marine engine without them.
Manley recommends them for Top Fuel, Funny Car and Marine applications.
Pretty much sums it up right there.
#36
Tell The Wife Who The Boss Is And Buy The New Heads!Better Yet,Buy Them,Put Them On And Then Tell Her You Got Them!This Is What I Would Do Since Boating And More Hp Is The Most Important Thing In Life!All In All With All Im Considering Changing Out My Heads And Cams On MY 525sc's Am Just Staring My Research And Am Curious How Well This Comes Out!
#37
Originally Posted by RLW
Does anyone have the flow numbers for the Edelbrock Marine heads??
#38
Thanks,
Jeff
Thanks,
Jeff
They will not seal well on Gen V blocks. I know that there may be some special head gaskets out there, but I would recommend against it.
If you can not spend the $$ for after-market heads, then I would go back to your original thinking.
A set of L-29 Heads or Bigger valves in your existing heads...
Patrick
Patrick
#39
#40
After doing more reserch I am probably going to find a set of L29 vortec castings, I already have rockers, studs, valve guides and springs. All I need are the castings. If anyone has a good deal on a set let me know. I am located in the St Louis MO area.
Thanks,
Jeff
Thanks,
Jeff
