disc brake pads
Masher touches my
Re: disc brake pads
I am pretty sure they are the same pads GM uses on the Cavalier/Grand Am. They are only 20 or so dollars at any autoparts store. Take one set off and go match them up.
Ginger or Mary Ann?
Re: disc brake pads
Those are for the 225 calipers.
Heres a cross reference for the 250's. Bottom of the page.
http://www.kodiaktrailer.com/redswish/calipers-250.htm
Re: disc brake pads
picked up 3 sets semi metalic @29.00 each and 2 calipers 9.99 each lifetime warranty.Couldnt get ss,so I got steel and spray undercoating if they rust Ill junk em.Advance auto parts pretty good deal?
Location: A tree somewhere in the woods in Clarcona Fl.
Re: disc brake pads
Chrysler frt wheel drive pads,,depending on brand as to prefix but the pad # is 215(just did a trailer and had to mach them up) used raybestos pgd215m pads
Re: disc brake pads
On my Myco it had the Kodiak's 225's I belive the pads were 19.99.
I talked to Kevin at Kodiak at 1817-284-2324 He was very helpful!!! He did NOT recomend the metalic style pads beccause of it will rust.He said use the organic pads .I think they fit a 82-89 skylark,cavileir.The caliper # 6145 and 6146. They were about the same price direct then everybody else .
Also with in the last 3 years they are building the calipers with a anti rust coating and SS insides now.,
The calipers were the same as a 82-91 sunbird But I would still recomend getting the ones for Kodiak they are making there own...
These notes are from when i replaced mine . I bought the Calipers loaded from them.
I would ck with him on the 250"s
I hope this helps
Rob
I hope this helps
Rob
jordy
7
06-29-2005 06:52 AM
