Bravo X Drive
Charter Member # 1083
Does anyone know when they changed to the new streamline version? Do they have billet top caps? Do all of them (old - new), have the billet cap?
Thanks,
Bob
Thanks,
Bob
If it's not a thunder run.............than you're just burnen fuel!!!
Charter Member #601
Bob,
the new design came out last year sometime. The new case comes with a cap, that isnt billet but it is much thicker and has a steel tower in it. It can be used on the old case, but need to be shimmed accordingly, for proper setup..
Hope this helps.
Dick
Hope this helps.
Dick
not somuch stronger a little better design and harder to set up, one thing about merc when a patent is about to expire they change the design enough that the parts will have to come from them ie: gear changes 1.5 they changed to 1.47 ect guess it was time to change the housing
Thanks for the info guys. I didn't think Merc. would use a billet cap on that but, you never know. Looks good and beefy though.
I haven't seen the 2006 XR drives, do they use the same cap on them?
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
panteraracin
3
02-07-2002 10:36 PM
