Pro-Charger versus Vortech, & the winner is?
Originally Posted by RichardCranium572
Procharger is the biggest pile of crap on the market. Vortech's make more air, better air and quicker.
I am well aware of how the system works and as you know proper setup for the EFI motor includes having the ecu re-mapped to take it out of the the cold start mode it defaults to after removing the thermostat. Not biased at all here, like I said all the kits are good if set up properly.
AUTOCONNECTIONLLC.COM
Good info guys...Thankyou and keep the info coming, perhaps like Indy did in his post about speed gains after all it is the second half of the equation here.
Strip POker , I think that the price difference is very close at the time I am writing this. I know pro-charger usues a huge intercooler that I know has to help with the air charge temps.
Bryan
Bryan
Bryan,
When I got my setup it was after tons of research here on the board and had actually decided on the Whipple( the old kit) but in order to install it in my boat required cutting a hole in the fiberglass section behind the back seat for the pulley which I did not want to do. In the end it all boiled down to price, I found my ProCharger here on the board brand new for only $3500 from a guy who took it in on trade and have been impressed ever since. If I were to do all over again and had to pay the going rate I would probably lean towards the new style Whipple though. Just my .02 cents.
Have you ever put a wide band air fuel ratio meter on a procharger app? Do you even have a WB AFR meter? Never mind it's a ****ty charger compared to a vortech....can't even compare it to a whipple. Does it not concern you that they sell you a supercharger(hairdryer) without any computer mods on an EFI setup? They include a bigger fuel pump and have you remove the thermostat and crank the fuel pressure up. I know this works full throttle, but how much extra fuel are you unnecessarily putting in at idle and part throttle...let's not forget about all the soot on the back of the boat that gets on the girl's bathing suits.
As for biased morons, be careful not to put yourself in that category. I tune 2-3 supercharged engines a week, all over the country.
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
RichardCranium572 I dont think they relize what you do or who you are
You going to PRI ?
Rob
![Drink](/forums/images/smilies/drink.gif)
Bryan
Bryan
![EEK!](/forums/images/smilies/eek.gif)
Ck out Rtech on what they did with there innercooler its alittle tall but it works, its on top of the motor not hanging off the side with 10 feet of pipe.
When I cked on the Whipple vs the proCharger $$ it was about 2k diff. I know ProCharger gives a discount to dealers in Nov or Dec $500. per kit . That would help if the dealer passed it on to ya.
Good luck shopping
Rob
So what is the real world results with these systems? trying to figure this out and would like some real world feed back on installation , results and problems encountered with the system that you installed.
Also post Performance gains actually gained, before & After.
Bryan
Bryan
I would think you should be able to make 750 reliable hp with either system. I've been running the Procharger for 4 seasons now without a problem.
Originally Posted by INDY27
Bryan,
I installed a ProCharger Stge II sc on my 502 Mag four years ago and have had no problems related to the ProCharger, went from 70 gps to 85+ in a 27 Fountain. I also know quite a few people with ProCharger's on efi motors with no problems. If you have basic mechanical skills the install is a no problem but if you cannot put together a kids bike leave it to the pros. Vortech make a good kit and so does Whipple but in the end all of them are only as good as the install. Dont listen to biased people who say any of the kits are junk.
