BBC Heads HP500..What are they worth? >
Old 11-21-2005, 03:00 PM
articfriends's Avatar
Default Re: BBC Heads HP500..What are they worth?
Originally Posted by axapowell
Well, after researching heads, I've found out that the stock 088 castings flow pretty good for what they are and for the budget builder who has oval port heads, these are a great upgrade! Unable to spend upwards of $3300 on a set of AFR's and still get some of the features, stainless intake valves, inconel exhaust valves, 2.19 intake and 1.88 exhaust. Gotta cracked head or need a replacement head for an HP500? Valve spring upgrade already done $375 in new parts and that doesn't include the milling or the valve job! How can they NOT be worth even $900-$1200 a pair? You do know the casting? Large Rectangle port 118cc chamber?
For 1350$ a pair you can buy brand new merlin vr heads with Inconel valves,titanium retainers,10degree locks,thicker decks and 10% more flow than stock castings. 700$ a pair would be tops I'd expect you to get but maybe you'll get lucky and pull more out of them Do a search on E-bay on similar auctions and you'll find the answer,Smitty
articfriends is offline
Old 11-21-2005, 03:31 PM
I bought 2 sets of low hour takesoffs for $400 per pair to the door. These were complete. You can buy the new castings (Bare) from GM part number 6260482 or casting numbers 14096188 or 6272990 for $680 for the pair. Now unless you are class limited to OEM heads the better bang for the buck is an aftermarket head like a Merlin/RHS/Dart.
In your case with fresh heads ready to bolt on you will be lucky to get $600 to $700 a pair for them assembled. If you want to get the most $$ out of them I would suggest selling everything seperately.
cstraub is offline
Old 11-21-2005, 07:49 PM
Where To
axapowell's Avatar
Thanks for the help all!!
Dave
Next week...eBay for one set..think the other set is sold.
axapowell is offline
Old 11-22-2005, 05:54 AM
5PMSMWHR's Avatar
QUOTE "....think the other set is sold."
Axa,
Hmmm...., I didn't even know Ragged was in the market for more heads...............maybe 3rd will pick up the other set...
5PMSMWHR is offline
Old 11-22-2005, 08:04 AM
never hurts to have "spares"...
Rippem is offline
Andy
Wanted
6
03-19-2008 10:03 PM
Andy
Wanted
5
03-13-2008 08:57 PM
Fenderjack
7
01-14-2007 02:32 PM
iamfaster
3
01-22-2005 08:21 PM
Dave1972
6
12-09-2003 02:16 PM
Quick Reply: BBC Heads HP500..What are they worth?
