New to the BBC...
#51
Originally Posted by Longrange4u
I have found a performance engine producer that is going to build me a Gen IV 496 and balance it to the Gen V flywheel.
I had a 330 in my 1989 24' Pantera.
I changed the cam, intake, and added Imco risers to the stock cast exhaust manifolds, but did not touch the bottom end.
The cam was a Comp Cams, but I don't remember specs. I did not changes the valve springs in the peanut port heads so the cam was not that much bigger than stock. Oh, I did also rejet the carb.
Anyway, the engine went from a max of 4500rpm to 4900rpm with a 23p prop.
It ran great for about 120hours then it lost compression in two cylinders. I pulled it apart; two pistons had melted. Cast pistons can not take the heat of a high rpm engine. I would agree with the others that have said the cast pistons are the weakest link.
My suggestion to building up a low output 454 is to use better pistons, cam for 5000rpm max, and junk the peanut port heads.
I think $1500 for a set of Edelbrock large oval or $1300 for a set of large oval Merlins is $$ better spent than for a stroker kit. If the heads you have won't support the added cubes then it's a waist. And if you have to buy both, just buy a new 502 base engine...
![Drink](/forums/images/smilies/drink.gif)
Patrick
Patrick
#52
496 is a good combo. make sure you get the good valves manley severe duty intake and inconell exhaust. go for the better crank and make sure it has not been cut 3 times. adding a fordged crank and an 850 you will be at 5600. $400 more and I know where you can get a 540 / 625hp.
#53
![EEK!](/forums/images/smilies/eek.gif)
#55
![Smile](/forums/images/icons/icon7.gif)
Cast pistons also can have a piece break off of the skirt. It may have something to do with the manufacturing process, with the steel reinforcements in the skirts. I bought two 330 marine motors. When I cranked one over by hand I heard a knocking sound. Turned out to be a broken piston. Talking to a long established marina owner, this is common especially if motor is lugging (overwheeled). The reversion issue is very true, especially if using a big cam. I would suggest a max of .550 lift, 110-112 lobe seperation. Obviously the duration would be limited to keep overlap down, this will limit your cam selection down. I used the 365 mag cam. With head work, Large oval heads, big valves, porting, Better intake and holley squarebore carb., It really ran great in my 24' Formula, Until I lost oil from a cracked valve cover! and damaged the bottom end. ! Also dont waste money on an msd. They stop MSD'ing at 3000 rpm's anyway. They cost a fortune, have steel mechanical advances that break, due to poor spot welds at the factory. We ran the whole setup on a '38 Scarab with 572's. They provided no increase in power. I like the T-bolt IV. Very trouble free. You would be better off spending the money on the inside of the motor, Or on exhaust. My 2 Cents BBB
#56
Originally Posted by PatriYacht
It's not hard to make 425 hp with a 454. The weakest link is the cast pistons. If you can, replace them with forged. The rods are ok, better rod bolts are good insurance. I'd limit the rpm's to 5000 with these rotating parts though. Edelbrock heads are a good deal and they come with good valves. They will flow well enough for good power and oval ports make good torque. For 5000 rpm the biggest cam you want is the old Merc 420 cam, Crane #132561. .530/551 lift, 228/236 duration at .050. Holley 800 on an Airgap intake. Msd ignition. You can use stock centerrise exhaust with this and it won't revert.
#58
ECeptor... BBB...Kaama...zz... everyone that has helped me in this board I want to say thank you!!!
#59
These inconel exhaust valves...how important are they? I had a 502 built at the end of last summer by a reputable machine shop in Baltimore and those valves never came into consideration. It's basically stock except for .25 longer rods and a .550 hydraulic roller.
#60
Inconel is not important until you snap a valve off crush it between the head and piston cracking off the piston skirt and cracking the block. Thats Y they make sleeves.
