Crossover and external raw water pump on alpha?
yes and yes to both you can run a crossover and if you wanted to you can run an external pump but why would you want to????
would I have to add an external water pick up??....thanks doug
would a crossover only be too much for just the stock seawater pump......to handle all the pumping......sorry for all the questions
![Frown](/forums/images/smilies/frown.gif)
questions good, only bad questions are the ones that arent asked!!!!!....
the stock pumps should work fine with cross overs as long as you change them every year !!!
