Jesel Or Comp Belt Drive?
![Question](/forums/images/icons/icon5.gif)
What one do you think is better? I have used other jesel products and have been impressed. Price difference inform please. Thanks Cam-shaft
I have a Jesel set for a BBC that has about 10 hrs on it. if you interested. let me know. my plan was to E-bay it in the spring for money for a new prop.
CAM-SHAFT
I've used both and they are both great working pieces and the comp is less money I've used them extensively in my road race engines that I rent and never had a problem with either I have three engines I rent for Trans Am 310-320-358 ci one Jesel and two Comps great stuff. Sincerely Laz
Just be sure you change the belt out every 75hrs or 2 seasons on the Jesel stuff. They will tell you they last forever but trust me I know...I had a belt de-laminate....luckily it was at idle...just after coming off a 6200 rpm run....
I talked with Jesel and they had "never heard of that" before but did say they recommended changing them every 300 passes... If you figure 15 seconds a pass thats like every 75 minutes!! If you figure 1min a pass for start-up to shut-down thats only 5hrs of running time!!!! I left the Jesel guy speechless on that one.....but obviously boating is not quite like drag racing.
![EEK!](/forums/images/smilies/eek.gif)
I would think spring pressure and RPM would have something to do with the life span of the belt. Jesel told me to replace the belt every 40 hours.
1 Post
JESEL all the way. Ran one on my 540 SuperGas drag motor, 290#'s on the seat, 7500 thru the lights, changed every 100 or so runs. Never any sign of impending failure, just cheap insurance for my titanium valves. Standard equipment on every NHRA Pro Stock car, and they only run the best.
