Dielectric Grease for Electrical Connectors?
SORE MEMBER
1 Post
Re: Dielectric Grease for Electrical Connectors?
Originally Posted by offthefront
I would think it needs to conduct .. not sure if Vasoline conducts .....Kinda like the Time I cleaned my battery terminals with WD40 ....
BBB .... there is truth to waht you say about Merc .... God help em if someone every starts selling marine motors and parts half way resonable ....
If used on a clean connection it stops tracking and corrosion allowing the metal parts to stay in contact.
Vaseline is ok for some apps, but does not stand heat and probably does not have the dielectic strength of the grease.
Autozone sells an aerosol can that is a much better buy than the small packets
my bad .... just seems filling plug caps with DG would prevent good contact ..... I have seen Vasoline used on battery post and after a time it dries out and doesnt do the job .....
