Mercruiser Part Numbers HELP?
I am an hour from my boat, and have a crazy few weeks ahead, I am hoping someone might know part numbers or some other way to identify and locate some random parts. Thanks In advance.
Ok, The boat is a 1983 Excalibur Marine 40' hawk, original twin mercruiser 370 454 7.4L v-8. I just had the long blocks done and reassembled both, I need part numbers or help locating OIL PUMP GASKETS, ALTERNATORS, WATERPUMPS, and possibly MANIFOLDS. thanks
Kevin
![Drink](/forums/images/smilies/drink.gif)
Kevin
Ginger or Mary Ann?
Originally Posted by US1 Fountain
Were doomed!
heres the link for the 370: http://www.mercruiserparts.com/selec...doc_nbr=+86187
-Wally
-Wally
The internals/heads on the 330 will be different from your 370. But from your list, the only thing that might be different is the intake manifold gasket.
Thry this:
http://www.dolleroffshore.com/parts....pn=274&bn=1059
Thry this:
Thank you guys. I can finally get the parts I need with out all the guess work and trial and error I had gone through in the past. ( Bringing an oil pump around with me from shop to shop to match the gaskets was getting old) If I can ever return the favor to any of you please do not hesitate.
thanks,
Kevin
thanks,
Kevin
Ok, one more issue, I found the Mercruiser part number 817119A4 for the 55amp alternator, I am not sure if the 55amp or 39amp alt. is used on my boat. I currently want to replace the Motorola 8RG2018 alternator that is in it. Will the mercruiser part 817119A4 work?
Were doomed!
Go figure that the 55amp is cheaper then the 39 amp model!!!! anyway why dont you just have yours rebuilt? Last time i had one done it was a tad over $100 with a 1 year warranty....other then if the brushes go bad for some strange reason it will last you alot longer then 1 year
It will save you some money work just as good as new and you can still get more stuff
![Smilie](/forums/images/smilies/smile.gif)
-Wally
-Wally
