Hydraulic steering...Making progress
Well after a considering what to do and who to go with I have started on the system. I picked up a smoking deal on a complete system from a buddy who had one with little time on it about 2 trips, who did not like having it go lock to lock in 2 turns.
He upgraded to an ITS transom system and I benifitted. It is what I call the MAD MAX steering system, hynautic made the system and it looks old school to say the least. It consisted of:
2 Hydraulic cylinders : model # K5-B, nickel plated brass
Transom brackets
IMco ALuminum end cap for dual system
All the lines to use on a 26' boat
Resevoir
Hynautic helm Model # 41
preassure relief valve
The system was designed to be self contained using this large helm and a preassurized resevoir, I have however changed it over to a Charr lynn helm 145cc's and will use my pump to drive the system eliminating the resevoir. So i ordered some stuff from IMCO:
145 cc helm, 3 turns lock to lock with 9 inch stroke rods
Dash kit for 4 3/4 inch length
Filter
through hull fitting with a T for both lines from the rams.
MAn this sh*t adds up.
Just a note the prices have gon up from the web page on the dash kits, about 100 $ more than advertised.
So last nigh I removed all the internal steering stuff from the dash and off the transom plate( no turning back now) and found it is really not too bad of job. I am having a time getting the cable off the back power steering ram but other than that all has gone well, any hints on this? I am planning on just leaving the cable in the boat, but want to remove the power steering cylinder back there.
Now on to a big ? I have been measuring and looking at the mounting location on the steering ram brackets at the transom and am seeing that the upper bolts on the brackets will be no problem to through bolt, however the bottom bolts may be a problem due to the flooring in my engine compartment, it looks like either cut another access hole in the floor or just get some stainless lag bolts for the bottom and use some 5200 on them, any ideas?
I will have my dash stuff Friday and should finish the job next week sometime, if all goes smooth. I am going to have a time pulling the lines to the dash I have a feeling, again any suggestions?
Hopefully steering into the future safely.
Bryan
![Evil](/forums/images/smilies/evilB.gif)
Transom brackets
Resevoir
Filter
![EEK!](/forums/images/smilies/eek.gif)
Bryan
Payton
03-20-2004 12:35 PM
Mr Gadgets
01-15-2002 11:56 AM
