Winter Project
#31
Re: Winter Project
Originally Posted by 79excalibur
I don't know if you have figured out your seawater pumps but some one could have replaced them along the line and mounted it upside down. If it is the older sea water pump that mercrusier used on everything for years and years. For we hooked one engine up the correct way and the other opposite with the hose switched. And it would still pump water just not the same volume as the other, but that was hooked up to a hose and not in the water. There is my 2 cents. I am glad to see you are moving along nicely. Reminds me of last winter for us. and yet mine never hit the water last summer lol. Good luck and I will post my pics soon so i will share my hardships.
David
David
#32
Re: Winter Project
I received word from Roccard Marine that my engine dyno is scheduled for this Thursday.All my parts are in and should have assembly done by Tuesday.Mike from Roccard says my finale compression ratio will be set at 9.8 to 1.This seems a little high but he says with aluminum heads there will be no problem with running regular gas.What are your opinions out there in o.s.o. land?I also started asembling my gimbal rings and transoms tonight.What a pain in the a$$.I have all respect for you guys that do this day in and out with them mounted on the boats.Here are some pics from Roccard.
Thank Nordic95
Thank Nordic95
#37
Re: Winter Project
Just got back from my dyno session.I have to admit that Mike from Roccard was a hell of a lot closer with his prediction then I was.Here are some pics and the dyno sheet from one of my engines.Tomorrow we will dyno the other and then back to my garage with both of them to start the assembly process.
Thanks Nordic95
Thanks Nordic95
