Thermostat housing
Thermostat housing
I just received my new stainless thermostat housings today and I see there are no provisions for the water temp sending unit and the over heat sending unit like on the orignal housing.
Where is the best location on the motor to relocate these units now?
Thanks Nordic95
Thanks Nordic95
Re: Thermostat housing
depends on what motors you have but on most there are provisions in the water jacket cross over in the in take manifold where the therm housing bolts on to the left and or right
You can put the alarm in the side of the circ. pump.Should be a 1/2 pipe fitting just above Circ. pump large hose nipple.You'll have to use 1/2 x3/8 reduser and lenghten wire.Merc used to do that years ago.
SORE MEMBER
1 Post
Originally Posted by nordic95
No,everyone is telling me to stay away from cross overs.
Bypass wasn't installed in this picture
