oil temp sensor....
ok.... obviously have the boat up and running and reasonably dialed in and sea trials done and ready to do the final fitting out. carpets , put all the screws back in the dashboard and interior, put the head liner back up that fell down the other day after a long flight and hard landing... etc etc...
at anyrate.... the dash has oil temp gages as you would expect and the old motors had oil temp sensors drilled into a adapter plate that was used to remote mount the oil filters.... i can't see anyplace on these 502 mag mpis to put the oil temp sensors unless i put that sandwhich plate back in which i can do but they're ugly etc.... remote mount the filter is un nec in this case....
question... is there a factory provided port anywhere for an oil temp sensor that anyone knows about before i invent one ?, please.
SORE MEMBER
1 Post
People have mounted them in the 3/8" port above the oil filter adapter pad on the block. As you would probably do on the dyno. Dont see any harm in this. This would reflect oil temp returning from the oil cooler I beleive and that would typically be 25* less than oil pan temps. (pre-cooler)
Patrick
Patrick
SORE MEMBER
1 Post
The places I can think of are
1/ oil pan,
2/ 3/8" port mentioned above
3/ oil filter adapter, which may need a ground
4/ make fitting to go in oil line to oil filter which would also probably need a ground
5/ change out oil temp guages for water pressure guages
1/ oil pan,
SORE MEMBER
1 Post
Originally Posted by cstraub
We recommend the pan...
yes to all... and i am looking at either a sandwich under the filter or an adapter in the line.... both easy and straight fwd . was just hoping there was an easy 1/8 pipe plug somewhere i missed.... wheres santa when you need him ?
SORE MEMBER
1 Post
no place that i would consider saffe to do it... thin wall everywhere and no blank bosses or anything.... first place i looked
cloudmaster_321
Do It Yourself, Boating on a Budget
2
10-19-2008 07:14 PM
