Installing hydraulic steering.
Well just about finished with this install doing it myself, the thing is not to bad of an install other than drilling holes in the transom...
I have the whole thing done except for mounting the rams on the transom. I used an IMCO end cap and drilled out the extra holes for the end cap...not to scarry, drilled new holes in the dash for the new style IMCO helm , again not too bad...now lets get to pulling the 4 hydraulic lines...what a pain in the arse!, it is done now but what a pain. Mounted all the adel clips on the hydraulic lines and the securing of the filter... Now it was time to drill holes in the transom for the oil line tubes ....I put the fitting right above the outdrive and on fitting will feed both rams , nice and clean. That was kind of weird drilling holes in the transom but now .........
I still have to get the rams placed and bolted up. This is where it is getting scarry. I have yet to actually drill the holes....that is today. The rams I am using are Hynautic K-5 cylinders and have a big mounting bracket attacthed to the ram with a solid u joint type connector and I am having a time getting the propper dimension for the mounting location. I have the propper plane to the crank center line but the dimension ffrom the gimble housing is another story. What I have done at this point is connect the ram, put the drive full over and compress the ram all the way and mark on the transom, next extend the ram full over to the other side and mark the transom. I have done this on both side and the marks are equall on both =sides but they differ about 2.5 inches from full lock to full extension on each side make sense . I guess the only thing to do is make sure tha placement puts these rams when the port ram is fully compressed and the starboard ram fully extended , and the same on the other side, this is my turning radius and that is that. Am I correct? Just drill the holes !
Thanks.
Bryan
Thanks.
Bryan
Re: Installing hydraulic steering.
"I guess the only thing to do is make sure tha placement puts these rams when the port ram is fully compressed and the starboard ram fully extended , and the same on the other side, this is my turning radius and that is that."
That is the ideal situation. Although when I installed mine that was not possible no matter where I mounted the rams.
I hate the winter!!
I would be real careful about where those rams get mounted. The last thing you want is for them to bind up when under load. I installed Imcos setup on my boat. The installation instructions gave me exact dimensions and templates for exactly where they want the rams mounted. No guessing that way.
Well it is all finished except getting the lines made for the rams outside. Measured , and measured until I thoght it was right and it is. Full lock extended = full lock compressed on the other side and Vice versa.... This is tough to do by yourself with no extra hands....and no guide to go by. The guys at IMCO said it was ok to be above the crank centerline by an inch....I am above it by 1/2 inch, this kept me out of the stringer support and allowed me to through bolt all 4 bolts on both sides.
I don't like drilling holes in my transom....Glad that part is over.
And here is where I put the feed tube for the hydraulic fluidjust above the gimble housing......Lts of silicone went into this hole as well as all the others
Originally Posted by jhiguy377
hey bryan, how much did the setup cost?
jeff
jeff
I got a deal on the rams and 3 of the long lines though from a buddy
Bryan
I'm guessing your 2.5" differential was from the drive not swinging fully one way or the other. Tiller arm hitting inside?
Anyway, looks like you got the job done. I built almost the exact setup on my 38 scarab. Loved it. Those rams are REALLY solid. Although mine was non power assisted too, so slow speed turning with twin TRS was a workout.
finished it a while ago , need to work on routing the lines better.....and also put the beauty rings on the pipes.
Bryan
Bryan
