Mercruiser Engine Problem >
Old 01-12-2006, 07:47 PM
  #71
GOODT's Avatar
Default Re: Mercruiser Engine Problem
here you go heres the bulletin...took me a few to find it
GOODT is offline
Old 01-12-2006, 08:01 PM
  #72
Thank you for the info. Also I wanted to know do you know where I can get that filter? Searched for it and could not find it anywhere. Thanks.
studstud1 is offline
Old 01-12-2006, 08:11 PM
  #73
GOODT's Avatar
merc dealer should have it if not they can order itmost have the kit in 02 it was a retro fit for all 496s
GOODT is offline
Old 01-12-2006, 08:12 PM
  #74
GOODT's Avatar
in new boats the metal from when they made the fuel tanks and drilled the holes out that was left in the tanks was killing the boost pumps
be advised mercury is VERY VERY proud of those kits they sell for over 100.00 I think. Its a filter and a bunch of fittings to put the filter inline.
GOODT is offline
Old 01-13-2006, 07:13 AM
  #75
Talking Re: Mercruiser Engine Problem
Originally Posted by GOODT
and if the radio stops working check the tps
Joe:
Years ago I did an engine oil and filter change on this girl's Chevelle. That's ALL I did.
She came back screaming at me that I broke her cigarette lighter! True story.
Ed
Edward R. Cozzi is offline
Old 01-13-2006, 04:45 PM
  #76
Ginger or Mary Ann?
US1 Fountain's Avatar
Originally Posted by Edward R. Cozzi
Joe:
Ed
Maybe she just really wanted a date? Kinda like leaving your car keys behind.
US1 Fountain is offline
Old 01-13-2006, 06:13 PM
  #77
GOODT's Avatar
think it was her way of saying she wanted a little.....
Happens all the time, (not that some 300 lb guy wants alittle)
......you changed my drive lube now the radio doesnt work what did you do...
dont know a tech anywhere that hasnt heard it atleast once or twice
GOODT is offline
Old 01-15-2006, 05:13 PM
  #78
Loose wire on my ignition. Same thing, only under load which is what threw be off. I guess the boat wasn't bouncing enough below 2000 RPM'S
CN24 is offline
Old 07-07-2019, 05:10 PM
  #79
Default Engine power
I've changed theSpark plugs, fuel filter, fuel filter to the carburetor the fuel pump and the fuel, and still it only starts and runs for 2 seconds after I pump the throttle, now I'm ordering a new coil pack, what do you think the problem could be. Prior to this when the problem first arrose, I was running fine and suddenly the I lost power for a minute and then it would regain, then die down and regain and that's how it continued to operate
Donbc is offline
Old 07-07-2019, 07:47 PM
  #80
What year and engine? Get a test light and start checking for voltages at the coil with key on and in run mode.
PA.WOODCHUCK is offline
Quick Reply: Mercruiser Engine Problem
