575sci oil thermostat opening temp?
Anybody know the Merc oil thermostat temp spec used with the 575sci oil cooler? I just changed the water stat and know that it is 140. Is there somewhere that Merc gives this spec? If anyone has a pic and description also of where the oil stat is located it would help. If I knew where to locate it maybe I could remove it and take a look.
Dave
Dave
Re: 575sci oil thermostat opening temp?
Here's a picture of where it's located:
http://www.mercruiserparts.com/Show_...er%28Engine%29
I would bet it's going to be around 210*.
That's where my HP500's were.
( just hot enough to boil off condensation)
