camshaft wear
Geronimo36
Re: camshaft wear
Originally Posted by formula31
Since I have an engine apart and it needs a new cam, I will bite the bullet and go roller.
Re: camshaft wear
All worth it in the end though....Or so they tell me
Re: camshaft wear
formula31, you mean you are going to go roller in one engine and flat tappet in the other? I'm wondering if the GM additive that RMBuilder recommended for break in would be a supplement to use all the time?
Re: camshaft wear
Ok, nevermind. I went through finances and what this was gonna cost me and what I had to still spend (ive got both drives apart too) and chickened out. I ordered a replacement for the flat tappet. Im gonna use Rotella and eos. Im also gonna lean up the carbs a little this year. Comp Cams has some stuff too Im gonna look into. I may also groove the lifter bores to get better oiling of the lobes. The roller cam was gonna be another experiment as far as reversion and power and I am very happy with what I have now. Ill just hope the new casting is better than the last.
Geronimo36
Re: camshaft wear
I've learned from my mistakes. Put a hyd. flat tappet cam in my 580's last winter. Lost a lifter and cam lobe within the first 2 hrs. Cost me $2K to fix the damage...
I still cross my fingers everytime I start up the motors.
Re: camshaft wear
The first 2 hrs. was the break-in period. Guess you had real junk from the get-go or the break-in additives and/or proper procedures were not used. And, I DO prefer roller lifters. It's just that it's not really practical for everyone to convert; and done properly, flat taps will do the job! --- Jer
Geronimo36
Re: camshaft wear
I think one of the lifters must have stopped turning. Second time around was good because someone with some sense put it together.
I still have my druthers and would rather go roller. Also, the dyno results were less than stellar with the flat tappet, I'm at least 75 hp off.
Re: camshaft wear
Really shouldn't be 75 hp diff. with just the lifters; BUT, you can use a better (steeper ramp) cam with roller lifters and make more hp with less drag, heat, friction, and wear. If it's in the budget; GO FOR IT! --- Jer
Re: camshaft wear
Ive always had good success breaking them in but I follow all the rules. Except the one about spining the lifter by hand if it doesnt start spinning on its own. Ive never figured out how to accomplish that one.
The one I have to change apparently was a bad casting or bad heat treat. Lifters were fine and lobe peaks were not worn off, just missing pieces.
