Indicator cables >
Indicator cables
Indicator cables
Old 01-18-2006, 08:43 PM
GOODT's Avatar
Default Re: Indicator cables
Good Luck....lmao
GOODT is offline
Old 01-18-2006, 08:46 PM
Masher touches my
Outdrive1's Avatar
I got one from Livorsi for my trim indicator the other day and it was blue, I don't know if one type is better than the other but that must be what they recommend. I planned on putting some extra silicon in the fitting even if it does feel like a good seal.
Outdrive1 is offline
Old 01-18-2006, 09:05 PM
cuda's Avatar
What brand were they? I heard of some real good one's called Northwestern, or something like that.
cuda is offline
Old 01-19-2006, 04:30 PM
Masher touches my
Outdrive1's Avatar
Pretty sure it was a Teleflex cable. Not sure of the model number, I'll look at the box and shoot that over.
Old 01-19-2006, 07:28 PM
nordic95's Avatar
Here are the cables I received.They seem fine just a smaller jacket then the reds.The company I bought them from says that these will be just fine for indicators.It turns out they are a lot cheaper then the reds also.But I know the saying,"You get what you pay for".What are your thoughts?
Attached Thumbnails Indicator cables-100_0409-medium-.jpg   Indicator cables-100_0411-medium-.jpg
nordic95 is offline
Old 01-19-2006, 07:35 PM
Ted G's Avatar
They are standard 3300 style cables, likely the same thing that was on there new. Even quality manufacturers usually don't use Red Jacket Supremes on indicators because they are about double and overkill for indicators. If you are going to redo the controls use the best-either Red Jacket Supremes or TFXtremes-there is a huge difference in feel and control.
www.cbpba.com
Ted G is offline
Old 01-19-2006, 07:37 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
It's just a cable to move a plastic pointer. You're worrying too much.
US1 Fountain is offline
Old 01-19-2006, 08:08 PM
21 and 42 footers
t500hps's Avatar
My Formula came with Red Jacket Supremes.....
t500hps is offline
Old 01-19-2006, 08:15 PM
Ted G's Avatar
Maybe mine did too But it's got standards on it now
www.cbpba.com
Ted G is offline
Old 01-19-2006, 08:30 PM
cuda's Avatar
I need to replace all four on my 302. It has reds on it now.
cuda is offline
Quick Reply: Indicator cables
