Bravo 1 trim indicators?
I have twin Bravo 1s and Faria guages for trim indication. The guages work intermittently.......
What is most likely the problem?
Thanks.
Thanks.
more then likly its in the senders, but could be any number of things from a bad ground to bad gauges but most times its in the sender leads....
you didnt give very much info...ie: make model type drives ect
Could also be the wires are corroded. Replace the sending units, simple and only $80
![Roll Eyes (Sarcastic)](/forums/images/smilies/rolleyes.gif)
I agree, probably senders, round modules on top sides of outdrive. Sort of a wiper effect sender, just two screws to take them off.
1bigjim
glad you think simple to replace...25 years doing this...easy for me but without the right tools and exp. not easy or simple....requires disassembling the transom bell housing(waiting for you to say splice them in..will only live a short time)
![Wink](/forums/images/icons/icon12.gif)
OK I will agree. If you have done it before its simple. It really is
No I would never splice a line, that's why you buy the complete kit.
SORE MEMBER
1 Post
If you can get it off and apart, clean it thoroughly and fill with di-electric grease. This has worked well for me. Note where it is before loosening the screws.
