Boat Bling
#31
here's the finished product of the first pic in my last post. this is a dry sump oil pump braket for the god father of power ZUL. the prince of power, J.C PERF, has also ordered 2.
#32
Wow you do some fine work.
Great craftsmanship!
Monstaaa what is the coating on the scew terminals?
Gerry
Gerry
#33
Gerry
Gerry
if you do a dash likeyou show there do you splice the wires into the harness or terminate them along with the harness ?
#34
the coating on the terminals is liquid neoprene.
as far as the wires go, they do terminate under the dash v.i.a ringlets to a terminal block. i feel use of cannon or fireplug's leave room for possible interrupt during violent impacts such as in racing or poker running. also each wire is terminal ended from pole to pole , so if there is a problem with a circuit you can change the segment of wire independently if needed.
#35
Gerry
Gerry
#40
![Thumbs down](/forums/images/icons/icon13.gif)
Originally Posted by cuda
Yes it is, I can't even find these sorry ones anywhere. ![Frown](/forums/images/smilies/frown.gif)
