Cylinder head CC question >
Old 02-10-2006, 09:34 AM
Default Cylinder head CC question
Does anyone know if the Mark IV cylinder heads for the 365 mag and 330 "peanut port" heads have the same CC volume?
Gary
rdoactive is offline
Old 02-10-2006, 12:06 PM
formula31's Avatar
Default Re: Cylinder head CC question
I believe they are both 119 cc or thereabouts. You can check the casting numbers on www.mortec.com.
formula31 is offline
Old 02-10-2006, 12:15 PM
.. ..also casting will vary from what the OEM specs are. One pair listed as a 119cc may be 122cc and another set may be 124cc. If you are boderline on a safe compression ratio your best bet is to have the heads CC'd.
cstraub is offline
Old 02-10-2006, 12:17 PM
Thanks,
Just wanted to know if swapping heads would change the CR.
Gary
Old 02-12-2006, 11:37 AM
Magnum heads should be Rectangular ports. The best bet would be to get the casting numbers and check mortec. I replaced my peanut port 118cc heads with a set of Large Oval (820s)110cc heads and picked up compression. You can CC the heads yourself with a piece of plexiglass some grease and a surenge. This will give you a pretty close estimate. You could have your heads milled down and pick up compression you may drop 3-4 cc's and pickup .3 compression points.
jeffswav is offline
jijo
0
02-20-2008 12:28 PM
Audiofn
1
11-16-2004 12:08 PM
MAG502NUM
1
05-20-2003 10:27 AM
kaama82
33
02-28-2002 12:21 AM
Quick Reply: Cylinder head CC question
